Idle air control valve
I have a 2000 OHV 4.0 that is in need of a new idle air control valve. I went to advance today to see about getting a new one. They couldn't find a part number in their computer of book. THe only thing close was one for a 97 4.0 We tried pulling the numbers off my stock one with no luck. I am asking a couple questions.
1) Would the part off of the 97 4.0 be compatable?
2) Does anyone have the advance or Ford or similar part number?
3) Can I clean this valve or is it something I should spend the 40 bucks to replace?
Thanks for the all the help.
-Luke
-Luke
Originally Posted by SoundPer4mance
that hilarious that you took a pic of the box with the part number. some people have too much time
Originally Posted by shadyluke
Funny as it might be itz also awesome that he would do that to help someone out.
Well I finally got my part. They had to special order it. I noticed when I pulled the old one off tho that it had a spring inside and the new one didn't. Is this a defect or is it just a different design. Otherwise the structure of the part is identical. I installed it and it seems to run fine and idle properly. Could not having this spring lead to premature failure of the new part tho or am I just dumb and it doesn't need it.
Thanks again for the help,
Luke
Luke
It probably doesn't need it because it is made up for in some other way.
The IAC works more or less like a loudspeaker or a solenoid. Some kind of resistance (like a spring) holds the valve closed. Then a pulse-width modulated signal pulls it open. The signal is similar to what fires your injectors. The wider the pulse, the more the valve opens. Simple.
I wouldn't worry about it if it's working well. About the only thing that can go wrong on them is an open or shorted coil or mechanical "stickiness". They have an internal coating that is supposed to keep gunk from sticking to them so that they don't jam up. That's why they are not supposed to be cleaned with solvent.
brc0703
11-14-2012 08:46 AM
Liquidswords32
05-11-2011 12:33 PM
Liquidswords32
05-10-2011 10:24 PM
BRENSRANGER
01-07-2008 06:41 PM
